Can someone point me in the right direction for a step by step guide to install the LM1 with Flashscan V2?
What should the log works settings be on each tab?
Is it? :
0 Volts to be 7.35 AFR.
5 Volts to be 22.35 AFR
When these settings are saved, it jumps to 4.996 volt at 22.34 air-fuel-ratio. Is that normal?
Whats the difference between analog out 1 and analog out 2? How do I know which one I'm using? Should I set them both up the same?
Thanks!
