Results 1 to 4 of 4
Thread: V2 flashscan with LM1
    Jun 2006
    Default V2 flashscan with LM1
    Can someone point me in the right direction for a step by step guide to install the LM1 with Flashscan V2?
    What should the log works settings be on each tab?
    Is it? :
    0 Volts to be 7.35 AFR.
    5 Volts to be 22.35 AFR
    When these settings are saved, it jumps to 4.996 volt at 22.34 air-fuel-ratio. Is that normal?
    Whats the difference between analog out 1 and analog out 2? How do I know which one I'm using? Should I set them both up the same?
    Thanks!
    Jan 2005
    Should be a similar install as the LC-1 tutorial found in the scan or tune tools Help menu.
    Aug 2007
    Quote Originally Posted by TAQuickness View Post
    Can someone give a hand for a dummy. I am needing to hook up my V2 to a lm1 and a lc1. Its so simple most post skip over it and go straight to installing software. Also, an explanation of serial verses analog would be great. I would love to do this ONCE.
    THANKS in advance!!!
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
    May 2007
    I would like to know also. I dont want to replace my nbo2 , I just want to hook my lm1 into my v2.
    I may not be reading it right but on my analog cable with the lm1, there is a red, white and a brown wire. where would these hook up?
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
  1. FlashScan V2.0?
    By bobfo in forum General
    Last Post: October 7th, 2005, 02:20 AM
  2. LC-1 with Flashscan for 98s
    By dlandsvZ28 in forum General
    Last Post: August 24th, 2005, 05:44 AM
  3. Will flashscan
    By mgarfias in forum General (Petrol, Gas, Ethanol)
    Last Post: December 2nd, 2004, 05:27 PM
