Results 1 to 5 of 5
Thread: Cobalt .cal files
    Default Cobalt .cal files
    Hi All,
    First up, many apologies for the ongoing P12 delays, however, it's not over yet. We have decided to rethink how much P12 support we will eventually offer. What we have done is offer at least some preliminary calibration files for the Cobalt / ION / Atom which seem to be the vehicles everyone wants to tune with these PCM's.
    These were developed mid year and we just recently added a couple more tables in for this release.
    This should not be considered a final .cal file release for these engines as there is only 50 or so parameters / tables available.
    You will find however there is enough to make a reasonable gain in tuning one of these motors on standard and modified engines.
    Supported OS's are -
    12601774
    12605256
    12605261
    12610624
    12610647
    12610648
    We may release a Trailblazer / H3 .cal set similar to this to tie everyone over until we can do a complete release for these PCM's in 2008 sometime.
    Forum P12 section has also been washed clean if you were wondering where all the posts went.
    To use these calibrations, unzip THIS file in to the folder -
    C:\Program Files\EFILive\V7\Calibrations
    Oct 2006
    Quote Originally Posted by GMPX
    Hi All,
    Trailblazer / H3 .cal would be nice to see .
    Give us all the P12 .cals you can .
    2006 Trailblazer
    Lifetime Member 98 tigershark's Avatar
    Nov 2006
    So I cant read my sons cobaltss 06, and my wifes monte carlo ss 06 w/V1.
    I have scanned the cobalt and only a few items need to be cut by 50%, like HP and TRQ. It cant be that hard, can it?
    Sorry but V1 can't read or program the P12 PCM in your Cobalt. It's a memory size limitation in V1 that is only an issue on certain controllers, the P12 being one of them. The MonteSS is a 5.3L right?, that is a CAN based controller if it is, the V1 cannot communicate on the CAN bus.
    The Monte can be read by a V2 AFAIK (check the supported vehicles list) and if you can pull an OS ID from the Cobalt SS look and see if its one of the above OSs to see if the tables have already been written for it.
  1. Cobalt rental car
    By cmitchell17 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 21st, 2010, 10:25 AM
  2. Any help or files for a 65lb injector setup on a 2006 Cobalt SS?
    By berrelauto in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 13th, 2010, 08:14 AM
  3. 07 Cobalt SS IFR wierdness????
    By Chuck CoW in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 1st, 2009, 10:58 AM
  4. 2.2L cobalt 2008
    By duramaxdaddy29 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: February 21st, 2009, 03:02 AM
  5. Support for 06 Cobalt ss/sc 2.0L
    By stkshkr in forum E37, E38 & E67 PFI ECM's
    Last Post: June 12th, 2008, 02:38 PM
