Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Unknown Bucking???
    Jan 2007
    Default Unknown Bucking???
    I decided to post this here instead of continuing with my trany thread because I no longer think they're related.
    I've been slowly tuning for the past few weeks and cannot find the cause of this bucking I'm getting at low RPM high Kpa.
    The situation is, as I pull up to an intersection and then go to turn and accelerate...not particularly hard, the vehicle bucks alot.
    It seems this vehicle is a one off...there is nothing to compare it to.
    Please have a look at my log and tune and see if anything stands out?
    Is there something else I should try logging?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Can you give some more info about the engine? What plugs are you use and what gap are the set at?
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Jan 2007
    Sorry...I knew I was leaving something out.
    98 4x4 Suburban
    5.7L Vortec
    Mercruiser Marine Intake
    Whipple SC
    2 bar MAP
    NGK...hmmm...TR6 or something (standard type plugs...not irridiums etc)...rings a bell. Sorry, been a while since I changed them. Gapped at .030 I believe...as recommended by many people.
    42lb Bosch green top injectors.
    4L80E transmission
    Running 98 octane fuel
    Thanks for taking a look
    Howard
    DUCT TAPE.
    Jan 2007
    Frame 4631 - 4646 is where a marker is placed that the bucking was occuring at one stage of the log.
    Howard
    DUCT TAPE.
    Unknown Zone TAQuickness's Avatar
    Jan 2005
    Any chance you have a '98 RR?
    I had a very similar experience with my 383 and it turned out to be a combo of the throttle cracker, spark, and commanded AFR. Looking at my logs, nothing seemed out of the ordinary, but by focusing on each of the three above with the RR, I was able to, by trial and error, find a happy medium that eliminated the bucking.
    Jan 2007
    Do you mean a 98 Road runner?
    No...I'm running a 99+ 0411 PCM.
    I think I may be able to convince Jez to let me hook up his RR again.
    Howard
    DUCT TAPE.
    Jan 2005
    I'd throw the RR at it. The low load bucking can drive you nuts fast with the log/tune methods.
    Jan 2007
    Last time...we thought we'd sorted it with the RR. It doesn't happen every time.
    Is there something else I should be logging?
    Misfires?
    Howard
    DUCT TAPE.
    Lifetime Member Doc's Avatar
    Oct 2005
    I take it you are trying to do a OLSD tune here? I do believe that P0101, P0102 and P0103 -the MAF performance enablers need to be set to "A: 1 Trip Enabled" in order for the MAF to fail and truly enter SD. Until then I think you are just in some quazi no man's land where the pcm is really confused...Not truly being in SD or MAF operation.
    I do see you have the P0102 failure on you DTC page- I normally see P0103.
    Maybe somebody more informed can elaborate on this...
    However, in the frames you referenced in this post you are somewhat rich during the bucking event. I did notice a couple of really lean spots (tho with low counts) Specifically at the 1200rpms 65-70 MAP.
    Overall, your commanded fuel values in B3647 seem kind of strange. Are you viewing your commanded fueling in EQ ratio or AFR? In the tune tool under properties, Display Commanded Fueling should be set to EQ Ratio.
    The only reason I say this is because when I "flipped" that feature to AFR(you have to close the tool and re open it) then the commanded fuel values looked more in line with what one would expect to see for a setup like yours.
    I have found bucking usually come from an unintended error in commanded fuel, air or spark. Spark seems to be fairly steady in the highlighted area
    I didn't see any WOT during this latest posted log. Did you ever do so? In this log that is??
    Finally are you using a V1 or V2?
    www.efialchemy.com
    www.greatamericancarwar.com
    Jan 2007
    Thanks for looking Doc.
    I'll check into the things you mentioned.
    Yes I'm attempting an OLSD tune.
    I'm viewing commanded fuel in AFR. I was viewing in EQ but it was recommended I change to AFR.
    I haven't tried any WOT (basically I'm scared). Lol!
    I'm concerned about detonation and the amount of KR I'm seeing and am worried I'll do some damage. I'd really love to be able to plant my foot...even just once. Lol!
    Oh..and I'm using V1 running cos3.
    Howard
    DUCT TAPE.
  1. Bucking Returns
    By Happy Jim in forum Gen III V8 Specific
    Last Post: June 13th, 2010, 08:22 AM
  2. ECM in unknown state :(
    By SmokinDuradog in forum General (Diesel)
    Last Post: September 2nd, 2009, 01:48 AM
  3. 1600 RPM Bucking Bronco
    By tazinhawaii in forum Gen III V8 Specific
    Last Post: September 24th, 2008, 08:09 AM
  4. No bucking....but pinging!
    Last Post: February 22nd, 2008, 01:43 AM
  5. Unknown VIN ???
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 2nd, 2005, 11:54 PM
