Thanks jfpilla.
Those figures were derived using the RAFIG/RAFPN process.
Could they still be wrong?
Thanks jfpilla.
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
It's worth trying. Desired airflow is important. Often when it's very correct other tables stay stock.
I prefer logging IACDES_B (IAC AIRFLOW) and using MAP B4307 A/C off RAFPN.
Start with the stock table and make the same additions or subtractions to both columns. Log from startup and idle to at least 92*C. I've never not had to finish by SOP.
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
Hmmm...still bucking!
Still looking.
How am I ending up with numbers as low as 10 or less AFR?
Howard
DUCT TAPE.
I logged IACDES_B and when using MAP B4307 A/C off RAFPN, these are the numbers I get.
-0.378317
-0.833999
-0.651416
-0.757419
-0.829980
-0.830892
I'm still getting the same bucking.
Here I marked it right as it was bucking at frames 7565 and 7571 ???? I don't see anything.
Howard
DUCT TAPE.
And here's another log...I changed the PE delay from 1 to 0 as per one dc_Justin's suggestion in another thread in order to get rid of the lean spike as I touch the accelerator whilst cruising.
I got some bucking at frame 7131....there's 3 markers next to eachother. I was hitting '1' as it was bucking.
Howard
DUCT TAPE.
Hi All,
thought I ought to post an update.
Found the cause of bucking...or so it seems.
I had a heater hose running against the ign module/coil.
Moved the heater hose away and no difference.
Swapped coils and it seems to be fixed.
No bucking in 3 days....and I tried to force the Burb to do so.
Howard
DUCT TAPE.
YEAAAA!
Congratz!
Thanks guys....I'm pretty happy I found it. VERY happy it's not the trany.
Now...back to tuning.
Howard
DUCT TAPE.
Congrats on finding the problem howard!
