Results 1 to 2 of 2
Thread: Trouble reading PCM tuned earlier with HPT?
    Lifetime Member Mr. P.'s Avatar
    May 2007
    Default Trouble reading PCM tuned earlier with HPT?
    Hi all -
    This weekend tried to read the calibration off a '06 TBSS and got the 'PCM is locked' dialog window; we called the person who last tuned the vehicle and was told that no he did not lock the tune, and HPT was the last software used to make calibration changes. However the EFILive scanner would work just fine, we were able to log data, I just couldn't read the PCM calibration.
    So my question then - are there different/incompatible communication protocols at play here? If so is there a workaround?
    Mr. P.
    Lifetime Member Doc's Avatar
    Oct 2005
    Ask the other tuner if they used a HP Custom OS. Sounds like he might of. Either brand can't read each other's Custom OS's and will give you the "locked pcm" when you try to read.
    www.efialchemy.com
    www.greatamericancarwar.com
  1. TT ZO6 tuned with EFI Live!
    By Redline Motorsports in forum Lounge
    Last Post: August 16th, 2008, 12:37 PM
  2. ve tuned now kr
    By mr.prick in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2007, 06:59 AM
  3. Can this be tuned out?
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2007, 07:48 AM
  4. DMA Pid trouble
    By MoTruck in forum General
    Last Post: December 29th, 2006, 10:47 AM
