Results 1 to 4 of 4
Thread: Nitrous timing retard
    Nov 2007
    Default Nitrous timing retard
    Is there a table in a 02 Z06 file that will retard timing when nitrous is activated? I think I have read of one in the custom operating systems but I want to run my stock system. If there is not one, does any one know if there is a piggy back system that will do it? On my 91' Z28, MSD made a timing retard box that spliced into the system. If figured with technology the way it is now there may just be a table for it.
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Why do you not want to run one of the custom OSs?
    Lifetime Member Doc's Avatar
    Oct 2005
    www.efialchemy.com
    www.greatamericancarwar.com
    Nov 2007
    I am more familiar with the stock stuff. Plus I like running the MAF for right now. The weather will change 50-60* a day where I live. An SD tune fluctuates too much for me in that big of a weather difference. I don't see or feel any power differences between the two at my level right now either. The car is still slightly under 500rw on a dynojet. I probably just don't tune well enough yet to notice any differences.
    What are some of the advantages for me to switch to a COS? If it is better I may go with it.
    Doc. Thanks for the link.
  1. Pulling timing for nitrous
    By SRT10KLLR in forum Gen IV V8 Specific
    Last Post: November 13th, 2009, 04:52 AM
  2. need to retard timing under boost
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 8th, 2008, 02:07 AM
  3. Timing retard
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2008, 10:25 PM
  4. 4 degrees timing retard needed
    By batesyellow01 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2006, 02:42 AM
  5. nitrous spark retard
    By maxxxboost in forum Tips and tricks
    Last Post: May 11th, 2006, 06:06 AM
