Results 1 to 9 of 9
Thread: v2 licenses question
    Feb 2006
    Default v2 licenses question
    Thinking of purchasing v2. my question is after swapping licenses will v1 still work as a back up for my car. I do know that I will not be able to purchase any new licenses for v1
    Thanks for the help
    If you buy the V1->V2 upgrade, you can copy/move licenses from V1 to V2...
    used licenses are copied, so that V2 has the same used licenses that V1 has
    (i.e. you don't have to pay twice for using the same PCM).
    Feb 2006
    will the v1 still work after you copy the licenses
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Quote Originally Posted by 88s10
    Yes, just can't add more licenses.
    Dave.
    Feb 2006
    That’s the answer I was looking for thanks biggsy
    Jan 2007
    No worries!
    Dave.
    Jan 2008
    Default V2 function question
    The FAQ on http://www.efilive.com/faq_tuning.aspx#Q3 mentions the differences between Personal, Comercial and Workshop.
    The Commercial version has 3 extra features not available with the Personal version:
    PCM locking, to prevent any other tuning tool from reading, modifying or overwriting the PCM’s calibrations.
    Electronic Throttle Control calibrations.
    Full reflash capability, which is required if you want to install a custom operating system. Once installed, a custom operating system can be tuned using any version of the EFILive Tuning Tool
    Do the restrictions apply with the V2, or is this a limitation with V1 only.
    Beersy,
    Welcome...
    V2 is available as Commercial and above (no Personal).
    V1 Personal->Commercial was a $50 upgrade, but now it seems V1 is only available as Commercial and above (no Personal).
    So that limitation now does not apply to either V2 or V1.
    Joe
    Jan 2008
    Thanks Joe for the excellent info. In light of that I have decided to go the Flashscan V2.
    Cheers
  1. V1 and licenses on 98 ECU?
    By LibertySyclone in forum FlashScan V1
    Last Post: December 11th, 2012, 01:36 AM
  2. Missing licenses!
    By Burnt_Bizcut00 in forum FlashScan V2
    Last Post: November 12th, 2009, 07:00 AM
  3. Transferring Licenses
    By 06Dmaxpwr in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 3rd, 2008, 08:37 AM
  4. VIN Licenses
    By schuter in forum Purchase and Shipping
    Last Post: March 18th, 2008, 08:59 AM
  5. Upgrading to V2 from V1....licenses
    By Chunx in forum FlashScan V2
    Last Post: May 24th, 2007, 05:55 PM
