Download these two files:
http://download2.efilive.com/Softwar...751_031_70.zip
and
http://download2.efilive.com/Softwar...811_012_12.zip
Update Dec 16, new firmware file V2.05.14:
http://download2.efilive.com/Softwar...ogV2_05_14.zip
This firmware update:
1. allows a trace file to be saved manually. Select menu: F2->F4->F1.
2. includes an update that may fix some LLY DTC and BB logging problems.
The ReadMe_First.rtf file has been updated to list the new features/options in this release.
If you have already upgraded to the new BB logging bootblock, then you do not need to (in fact you cannot) upgrade the bootblock again. Once it has been done, you only need to update the V2.05.xx firmware if/when new firmware is released.
There is new firmware (FSProgV2_05_12.efw) that you must program into FlashScan using the programming option in EFILive_Explorer.
Alarms have been fixed. Both Audible and Visual alarms are now working. As an example, the TP (throttle position) PID has been set up to sound an alarm and illuminate the second led from the left, (if LED Alarm mode is slected) if the TP goes aboev 95%.
The LEDs can be set to one of three states: Status, Alarms and Off. See Readme_First.txt for more details. The LED mode is identifed on the FlashScan screen to the left of the protocol display. Where S=Status, A=Alarm and X=Off.
The EFILive_Explorer program has been updated to include a trace window (check the Trace box in the status bar). The trace window will help track down drag/drop file copy problems.
The EFILive_Explorer program should now auto-detect and auto-connect to FlashScan.
The EFILive_Explorer program should now remember the last active folder and return there each time it is restarted.
The FlashScan firmware includes a trace option that will save a file with a *.efx extension at the end of a logging session. That file can be emailed to EFILive in the case of a log session malfunction.
