I send the trace info of the drag and drop issue.
I have them, but they aren't giving me enough info. I will add more detailed trace info and get you to try it again. At least now I know where to concentrate the more detailed trace info.Originally Posted by lakingslayer
See first post in this thread for updated firmware V2.05.14.Originally Posted by Cougar281
It includes changes that may halp fix the LLY problem.
http://forum.efilive.com/showthread.php?t=6900
Still can't reproduce the low power problem, did deleting the Settings.dat file from FlashScan fix that problem?
The link to the new firmware is not working.Originally Posted by Blacky
Paul, No, deleting the settings.dat file didn't change it.Originally Posted by Blacky
My badOriginally Posted by Ninety8C5
I've fixed the lin now
No luck with my LLY either....with FW V2.05.13 will go out and try .14 in a minute.
2005 RCSB 2500HD GMC Sierra DURAMAX LLY
1955 Chevy Truck 1st series, being restored
2002 Mercedes C270 CDI
This did not change for me with FW .14Originally Posted by Cougar281
Firmware .14 does not act any different than .13 on the LLY.
Maybe there is something I am doing wrong....
I go to F1 "Select Vehicle", select LLY Manual, select F1 or F2 to record or display data.
After selecting either one a screen comes up with a timer in the top row.
Below is a row called frames which is at 0.
Then there are a number of PIDs, more than in the options.ini file like AD1, AD2, Temp1, Temp2
Not sure if they belong there.
