Results 1 to 10 of 10
Thread: How to change AFR?
    Nov 2007
    Default How to change AFR?
    How do I change my AFR to make my car run richer down low? It bogs real bad til I get to about 2k because of lack of fuel.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    If your VE table is correct, OL commanded fuel {B3605} and PE table {B3618} will change that.
    Dave.
    Jun 2007
    One way would be to increase values in VE table for appropriate cells.
    Nov 2007
    The car bogs at take off and it showing extremely lean til 2k. So just change
    that section in the VE? BTW im in speed density if that matters.
    Jan 2007
    WBO2 shows lean?
    You need to do AutoVE to make you VE values correct.
    If (for example) you are commanding 12.8 A/F but WBO2 is showing 15 A/F, the VE table numbers for that part of the tune will need to be increased.
    If (for example) you are commanding 15 A/F but you want 12.8, the PE and/or OL Table values will need to be changed to command 12.8 A/F
    Dave.
    Jun 2007
    Quote Originally Posted by mikeyayell
    Changing VE is just one way. If you have not done the AutoVE yet you should try that. Follow the tutorial.
    You can also change the rpm at which Power Enrichment kicks in and eliminate the delay. If you're in SD, look at commanded fuel in open loop to see what's happening there.
    Spark timing can also be one of the causes. There's really no way to make a good guess w/o lots of info.
    Nov 2007
    I cant ever get my FAST to work correctly with Autove, so I am going to borrow a buddys LC-1. When I Autove does it change my ve table for me? Make it the way it should be? Also, what type of me ve table should I start with? I have forged 347 H/C/I
    Jun 2007
    The autoVE will adjust the VE table for you based upon your logged data.
    Read the tutorial to get famaliar with it.
    Stock VE table +15% maybe. I started with the 2002 LS6 table + 7% & went from there. You just need to be careful not to go lean as you are starting the process.
    Oct 2006
    AutoVE will map out what changes you need to make to the Vetable. It is only an automatic process when used in conjunction with a Roadrunner.
    Jun 2007
    I guess to be more precise, I probably should have said that the AutoVE will change your VE table, but you do have to make a few key strokes to apply the calculations to your table - unless you have Roadrunner. Again, follow the tutorial.
  1. HELP! cant change the OS`s over how do I do it?
    By LuthurUbU in forum General (Diesel)
    Last Post: September 3rd, 2009, 07:53 AM
  2. can i change the VIN in 05 LLY TCM ????
    By MARC75 in forum Allison 5 & 6 Speed
    Last Post: May 26th, 2009, 05:33 AM
  3. can i change my vin with EFI
    By MARC75 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 13th, 2009, 11:03 PM
  4. Cam change
    By jfclubby in forum Gen III V8 Specific
    Last Post: June 10th, 2008, 07:34 AM
  5. cant change VIN
    By Samdogmx in forum Vortec V6/V8 Specific
    Last Post: November 12th, 2007, 10:35 PM
