Results 1 to 7 of 7
Thread: Rev limiter help
    Oct 2007
    Default Rev limiter help
    I have a 00' TA that use to have an A4 that I have swapped over to a th400, so non of the factory tranny electronics are plugged in. I have turned all the rev limiters and the fuel cutoff up to 7500rpm, but I still seem to have a rev limiter @6500(I think the actual scan said 6638 or something) I do not seem to have this problem in the burnout. Truthfully it only seems to be on the 1-2 shift. but I think after it hits the limiter I shift the 2-3 early. so maybe itsanytime going down the track. Anyway, I can not seem to find anything. is there a speed limiter or something I'm overlooking? A buddy of mine never had this problem but he had swapped from a 6spd. so I was thinking maybe it had something to do with the A4 computer. please help!
    Jun 2007
    Did you change the Abuse Management parameters?
    Oct 2007
    I will check it. thanks.
    Oct 2007
    Quote Originally Posted by SOMhaveit
    yes it was changed. it is something else I'm overlooking.
    Sep 2003
    Quote Originally Posted by Badmire68
    Are you using the A4 .tune or did you change to a M6 tune file?
    I'm old and Retired! I used to go fast. I don't go so fast anymore ...but, my cars still do!
    Aug 2006
    I have seen the same conditions discussed on other forums, and the general consensus is to start with a manual tune.
    Oct 2007
    I'm using an a4 tune file. maybe that is it.
  1. 97 C5 Rev Limiter ?
    By Kool C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2007, 12:28 PM
  2. rev limiter
    By CWR in forum Vortec V6/V8 Specific
    Last Post: July 4th, 2007, 05:40 PM
  3. '98 LS1 Rev Limiter...
    By TNTFEDZ in forum Gen III V8 Specific
    Last Post: May 12th, 2007, 11:48 AM
