Jesse, here's a short run with Baro, O2 voltage, KR and a few other PIDs.
Like I said on the phone, the car is running very well.
As you can see Baro is 25.5. I don't know what sea level typically is?
Thanks for all the help
What is a normal barometric reading for seal level 72F?
Also, if anyone wants to see something interesting...here's my high idle problem and the reason I bought EFILive. Under certain conditions the car acts like it has a major vacuum leak. It seems to be triggered by the AC, but not exactly tied to it.
What happens is, I start to drive away and the idle will run up to 22ooRPM or 3300-3500 depending on the clutch being engaged. It will idle at like that with 0%TP until I either go 100% throttle until about 5,000RPM and let off. Here's a couple logs with all IAC PIDs on...it's too many channels, but I don't know which IAC I can turn off?
