are there any plans for EFI Live to figure out the manual regen for the DPF on an LMM truck? Other tuners have this feature, and for us guys keeping the doc and dpf this would be a great help. Some of the performance tunes I've tried cause the "clean exhaust filter" message to come up, likely because the power ranges of these tunes clog the filter faster than a stock tune. Then if it doesn't regen pretty quick it goes to limp mode. I had to re-load the stock tune for a while to get it to regen, yet the dpf is not shut off in the custom tune. I've read where others have had to do the same thing.
I know brand "Q" has the manual regen deal figured out, and wondered if you guys were working on it, or if anyone knew a way to command it.
Jody
