If I lower the throttle stop - my IAC count is currently 17 warm - will I need to redo the RAFIG or does it remain unchanged?
2000 Camaro SS Convertible
M6,
LTs, AFR 205s, Comp xer 220/224, LS6 intake, Ported TB, AR TT IIs
You will need to redo it. However, I think it will partly depend on how much you move your stop as well. You could get a way with making small adjustments and it will correct for it. But as much as I had to move my stop, it would have alot of problems correcting for it.
11 Silverado
08 Sierra
91 RS with 350 TPI and 411 ECM
OK, thanks. Did a little experiment and ran the the rafig at 67 steps, then 35 steps, and yes it changes quite a bit. Interesting......
M6,
