Results 1 to 3 of 3
Thread: Fuel Pump Voltage
    Senior Member SV8346's Avatar
    Nov 2007
    Default Fuel Pump Voltage
    I've heard a rumour that the gen3 and gen4 pcm also controls fuel pump voltage , is this true and is it also possible to alter the voltage going to the pump using efi live?
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Not true on commodore ls1's, PCM controls a relay which operates pump.
    Dave.
    Nov 2007
    i have looked into this a bit further and found out that the pcm does control the voltage to the pump but only on the VU and VY commodore utes.
  1. fuel pump control
    By THEFERMANATOR in forum Duramax LB7
    Last Post: August 9th, 2013, 06:13 AM
  2. Turning on E38 Fuel Pump
    By Tre-Cool in forum E37, E38 & E67 PFI ECM's
    Last Post: June 8th, 2009, 05:31 PM
  3. which walbro fuel pump
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2009, 03:42 AM
  4. fuel pump upgrade
    By ZL1Killa in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 21st, 2006, 11:58 PM
