I have a question about this table. Does this table operate all the time or just in PE?
The row values on this table are in GMEq. Do they translate like the following? Attached is my stock 4.8 table, I added the AFR column.
If so, does it mean given a certain AFR and RPM this is how much the PCM will add/substract Timing?
Does a Negative add timing and a Postive substract?
