Results 1 to 4 of 4
Thread: Update and solution to 98 PCM connection problem
    Jun 2007
    Default Update and solution to 98 PCM connection problem
    As some of you might have read, weve been having problems connecting to 98 F-Bodys with V2's, V1's have been working just fine, here is the original thread http://forum.efilive.com/showthread.php?t=6659
    well, it seems we have found a solution, strange as it may be. It seems when we open the scan tool, and try to connect, if we enter 97-98 PCM for controller type, it does not connect. But, for some reason if we enter 99-07 LS1 as the controller, the V2 will then connect to the 98 car just fine. Strange, but for some reason it works.
    WWW.EFIAlchemy.com
    Lifetime Member Garry's Avatar
    Jun 2006
    I played around with a 98 a week ago, and didn't have any problem reading and writing the PCM (apart from having to disconnect and reconnect after the write operation)
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    I hooked up yesterday to adjust some DTCs and selected the 97-98 and it hooked up fine, read the file, and then allowed me to write the change back without incident.
    Elmer
    Sep 2007
    I've tried to read with my V2 on a 98 Pontiac Trans Am and it wouldn't do anything at all. I'm going to try this, thanks for the tip!!
  1. Build 74 update problem
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 04:57 AM
  2. connection problem
    By 98RedZone in forum General (Petrol, Gas, Ethanol)
    Last Post: May 8th, 2007, 03:20 PM
  3. EFILive Connection Problem
    By jogasz28 in forum General
    Last Post: November 11th, 2006, 09:11 AM
