Results 1 to 4 of 4
Thread: DSP5 back to Stock Question
    Dec 2005
    Default DSP5 back to Stock Question
    Will a full flash back to stock leave no signs of the custom operating system from DSP5?
    Or is there another better way?
    That will leave no signs, it wipes everything.
    Dec 2005
    so now to go back to the custom operating system for DSP5 and my calibrations; a full flash with my previous base conversion file with the calibrations will do it?
    Apr 2008
    Yes if you are changing from a different OS then you must use the full flash option. Whether it is a single tune with different Os versions or going from a single tune to a DSP tune which is a different OS version. You can read the DSP pdf file in the help and see what a base OS is and when converted becomes a new OS version.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
  1. LS1 Edit back to stock
    By Chriskaw7r in forum Gen III V8 Specific
    Last Post: February 22nd, 2010, 04:32 PM
  2. ? Converting dsp5 back to single tune
    By boccheballs in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 29th, 2010, 09:22 AM
  3. COS3 back to OEM OS question..........
    By FreddyG in forum Gen III V8 Specific
    Last Post: July 19th, 2008, 02:17 AM
  4. Adding cats back in - some question
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2008, 11:41 AM
  5. custom os back to stock
    By minytrker in forum Custom Operating Systems
    Last Post: June 11th, 2006, 10:55 PM
