Well I got my VE table dialed in with in 1% so I decided to reenable my MAF to tune it via BEN correction. Everytime I would take my foot off the gas it would go way lean (18+) in the lower MAF Hz ranges. I would apply the BEN correction and it reflash then it would do the exact same thing. I have done this same process before my headers and new exhaust setup. I also put my WB after the Y pipe so it is farther down stream, previously it was next to the first factory O2 sensor... I don't think I have any exhaust leaks, do you think the placement of the WB is the problem? Attached is my tune and loggs.
AutoVE-002_0003 = MAF Disabled, AutoVE tune
AutoVE-002_0004 = MAF Enabled
Log_0003 = MAF Enabled Log...
Any help would be great!!!!
