Results 1 to 7 of 7
Thread: "Launch box" w/ COS?
    Lifetime Member Garry's Avatar
    Jun 2006
    Default "Launch box" w/ COS?
    I was wondering if something like this would be a worth-while project ...
    In order to improve launching to be more consistent, I had the idea of using the COS' valet-mode. Set the valet-mode RPM limiter to a certain value. Add to that a little circuit that, when primed, enables the valet mode. Once the clutch is released, the circuit waits for a configurable amount of time to let the car get enough traction before disabling valet mode and thus allowing the full throttle response ...
    Now, building the circuit is a $10 expense and an hour of soldering ... question is whether this idea is feasible ... and if so, where do I get a switch or sensor to hook up somehow with the clutch pedal ... using a manually operated switch would make the whole thing to complicated ...
    Comments anybody?
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Oct 2006
    With valet mode being a hard limiter I wouldnt like to be hitting it all the time.
    I remember Oztrack was using burst knock as a sort of torque limiter for launching but I dont know how succesful it was.
    Jun 2006
    Well, it would be used exclusively for - say - 2-3 seconds at a time while preparing to launch at the tree ... wait for both staged, first yellow, punch the throttle, wait another half a second, release the clutch ... something like that ... should work, or?
    Quote Originally Posted by Garry
    You could use the nitrous input to take timing out on the launch for a set amount of time , the valet mode is too severe for a launch as it custs fuel , not a nice thing for any engine
    Jul 2003
    Quote Originally Posted by Delco
    Well... I'd say.. .GO FOR IT.... I mean... Racelogic does traction control JUST like this... and they did it for the first time on a very powerful supra. I am doing this in my camaro... So... why not?
    Quote Originally Posted by Highlander
    Racelogic is a soft limiter , cuts one cylinder at a time for only one cycle and rotates it around the engine.
    the std PCM cut is very severe and harmful
    Jul 2003
    Well I stand corrected... I thought this was the way GM does it.
    Can't this be changed for it to be an ETC limiter?
  1. BBL Auto Restart After Entering "Power Saving" Mode?
    By swingtan in forum Black Box Logging
    Last Post: March 8th, 2011, 09:52 PM
  2. what table controls start up decay speed? "how fast it decays out"
    By mvvette97 in forum Gen III V8 Specific
    Last Post: March 20th, 2009, 12:10 AM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
