Results 1 to 10 of 11
Thread: Who runs a COS on a NA setup? Pros/Cons???
    Jan 2007
    Default Who runs a COS on a NA setup? Pros/Cons???
    I am thinking of switching to a Custom Operating System and I would like to hear about peoples different opinions... A couple of reasons I want to do this. First trying to dial in the MAF is a huge PIA.... Running in Open Loop with PE feels so much better than normal Closed loop MAF... Also I want to command 15.5 in the cruise regions for some better MPG...
    Oct 2006
    Quote Originally Posted by BlackGMC
    Started with a OLSD tune to begin with , runs great (over a year now) , but no real gain over a MAF tune .
    I run OLSD with out PE use the [B3647] for PE , [A0014] and [A0008] can be tricky to set up .
    Try it nothing to lose , and quite easy to do .
    I am sure dc_justin will set you straight .
    2006 Trailblazer
    Jan 2007
    Quote Originally Posted by tunedbyGM
    I don't have those 3 tables in my stock tune.... Are those added when you upgrade to a COS?
    Jan 2007
    Oh and do you need to adjust your tune for the various seasons? Like summer and winter? Here in texas summer can be like 100* then in winter is it like 40*...
    Jan 2005
    I've been running OLSD for about 2 years, and COS5 for about a year of that. The Alpha-N VE found in COS5 was what I needed to acheive a level of drivability that resembles OEM.
    Oct 2006
    Yes .
    2006 Trailblazer
    Oct 2006
    No , runs a shade better during the winter than the summer .
    IAT temps better during winter .
    2006 Trailblazer
    I'v been running COS5 in OLSD on my stock '01 TA (headers only)... I don't really need to run a COS or OLSD, but it has been a good educational exercise, and I have gone from 17 MPG to 22 MPG.
    It has been shown that SD and MAF produce the same TQ/HP... I don't disagree with that... TQ/HP depend on air, AFR and timing all of which can be made the same in SD or MAF modes.
    I have found that throttle response seems to be quicker with SD... i.e. engine responds quicker to throttle transitions (which also seems to make the trans respond in a postive manner).
    $0.02
    Oct 2006
    $0.02
    Very good summation (summarization ) !
    2006 Trailblazer
    Lifetime Member Biggsy's Avatar
    Jan 2007
    I agree
    Dave.
  1. Carbureted LT1 Runs on LS1 PCM
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: May 15th, 2014, 05:22 AM
  2. Pros and Cons on 2 ECM's
    By LostCause in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 20th, 2009, 01:02 AM
  3. procharged 383 with '96 efi only runs 14's @ 96
    By tommytooslow in forum Vortec V6/V8 Specific
    Last Post: February 20th, 2009, 06:47 PM
  4. 1/6th scale SBC that runs...!!!
    By joecar in forum Lounge
    Last Post: February 19th, 2009, 08:08 AM
  5. Pros: green horn stuck
    By Gonz in forum E37, E38 & E67 PFI ECM's
    Last Post: March 4th, 2008, 05:03 PM
