I was prompted to do a bootblock upgrade and it has been flashing 2 orange lights for a while (like and hour) .
It says "IN PROGRESS DO NOT INTERUPT"
So how long will this take or is it done??
If the Backlight turned off then i think it is done. At least that's the way I understood it when i did mine.
Ok well now I have turned it off or unpluged it, and when I replugged it in, I still get 2 orange flashing lights and no display.
I believe once the boot block has been updated you will need to apply a firmware before you can use V2 again.
What firmware are you trying to update to?
The firmware I am trying to update to is FSProg_V2_4_70
But it won't let me do it and it keeps saying it's not in deadpoll mode and it won't go into dead pole mode.
It says I have V2.04.04 (build 35) right now.
No luck so far.
how does E Explorer get info from the V2? Explain?
I don't know, the screen just stays dead when I plug it in and I get 2 alternating orange flashing lights.
I had to reload the usb drivers for mine to work.
E Explorer = EFILive Explorer that comes with EFILive.Originally Posted by duramaximizer
I don't understand the E Explorer....is that the same as the EFI Live Icon? It seems to have nothing to do with the software it is the firmware.
