Results 1 to 5 of 5
Thread: V1 Windows 64 Bit Drivers
    Nov 2007
    Default V1 Windows 64 Bit Drivers
    Hello & Happy New Year.
    I am new here. Well, first post. I have an 97 C-1500. With a L31 Motor, Marine Intake with a custom made adpater to work with the L31 Magnacharger unit. I am in the process of switching the PCM over to the 411 PCM using the 2002 Chevy Express Van calibration. Ok here is my question.
    My laptop is an DELL PRECISION M4300.
    It is running Windows XP 64. Before I make this dual boot. Is there an xp 64 driver for the V1 Hardware. I can not get it to work.
    Brian
    Jan 2005
    Welcome to the forum 97Blown! I'm not sure about the 64bit driver. I'll send a note to tech support for you.
    Oct 2004
    The latest releases have drives which support Vista 64, and probably XP 64 as well.
    Andrew
    EFILive Crew
    Quote Originally Posted by Tordne
    Available here:
    http://www.efilive.com/download.aspx#downloads4
    Nov 2007
    Default Thank you
    The 7.5 update did not install these drivers. I download the file and everything works.
    Thanks again for the fast replies.
    Brian
  1. Windows 7 & Drivers
    By BlkMax in forum FlashScan V2
    Last Post: November 22nd, 2009, 07:20 PM
  2. USB drivers Pop-up
    By white01ss in forum FlashScan V2
    Last Post: June 5th, 2008, 04:40 AM
  3. V1 and V2 same USB drivers?
    Last Post: March 27th, 2007, 06:51 AM
  4. v3 usb drivers
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: February 15th, 2007, 06:20 PM
