Results 1 to 4 of 4
Thread: LC-1's simulated narrow band
    Feb 2007
    Default LC-1's simulated narrow band
    On several occasions the PCM's throwing fault codes saying voltage to high and dropping it to what i think is limp home mode? Stalling and difficultly getting the revs up. Swithching ignition off and back on will cure the problem.
    I was wondering about the NB program settings.
    I have 2 wide bands which the indicator lights are both showing showing normal status.
    Anyone had simalar experience?
    I presume you are feeding the NB simulation into the PCM.
    When you log the narrow band what is the peak voltage?
    Maybe reconfigure the LC-1 to keep it below 0.9V (900mV).
    Feb 2007
    Yes i am on both banks, i'll try that thanks
    Feb 2007
    The sensors just needed to be air calibrated
  1. STFT Swings and Narrow O2s
    By Highlander in forum Gen III V8 Specific
    Last Post: August 18th, 2009, 06:56 PM
  2. Stock narrow band voltage outputs
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: August 20th, 2007, 09:38 PM
  3. Simulated Narrow Band with LC-1 on an LS2??
    By Rocketman69 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2007, 12:35 AM
  4. Narrow Band O2's......help
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 29th, 2006, 07:22 AM
  5. Question on scanning narrow band
    By 87gmc in forum General
    Last Post: May 2nd, 2006, 02:08 AM
