Results 1 to 10 of 15
Thread: cant read 2006 lbz allison tcm
    Jan 2007
    Default cant read 2006 lbz allison tcm
    I have had two occurences now of not being able to read the lbz/lmm allison tcm. one unit is a medium duty the other a regular silverado.
    Check status returns normal information.
    when try to read the tcm efilive gets stuck at
    initializing tcm,
    status bar never moves, two leds on right of v2 interface a blinking
    I have let sit for just over 5 minutes, hit the stop button
    and get the normal message of data transfer interupted.
    after several attempts the tcm data corrupts and efilive reports missing calibration. (have to reload using tech2)
    I have the december 31 bbl updates installed.
    any ideas?
    Lifetime Member Cougar281's Avatar
    Jan 2006
    I just discovered the same thing (Except I didn't corrupt the TCM.... I don't think). Neither the Dec 19 or 31 FW works with the 06+ TCM, and the Dec 31 does not work with the 01-05 TCM. Kept bombing out in the middle of the read (usually between 1 and 2 minutes).
    I'll check this when I get back on Monday, I don't think Paul has a 6spd Alli TCM to test with.
    Sep 2007
    Any update on this? I am still unable to read my LMM TCM even after the latest firmware update.
    Mike
    Nov 2005
    Need one? Email me and I'll get it going your way.. Or I can try to test this to see what's going on.
    Brayden
    Jan 2007
    latest firmware now works for 2005 and older but still no go with lbz/lmm tcm.
    07:51:28.421: Request GM VIN...
    07:51:28.625: VIN: if you need the vin let me know
    07:51:29.640: Preparing TCM for reading flash...
    07:51:29.687: TCM not secured
    07:51:29.703: Initializing TCM...
    07:52:03.812: Stopping, please wait...
    07:52:06.906: Total time: 00:35
    07:52:06.906: Rebooting TCM... (please wait up to 8 seconds)
    07:52:08.078: TCM has booted successfully...
    07:52:09.093: Clear emisison related DTCs...
    07:52:09.140: Clear DTCs for all modules...
    07:52:11.312: CAN-VPW Bridge Actived
    07:52:11.359: Current protocol set to: "ISO 15765 CAN"
    07:52:11.453: Interface firmware version: 2.5.15
    07:52:12.843: Disconnecting ...
    07:52:12.906: CAN-VPW Bridge Deactived
    07:52:12.921: Disconnected
    07:52:17.375: Done!
    at 07:51:29.703: Initializing TCM flashscan will sit there until i hit stop button.
    Jan 2007
    any update on this? still cant access any of the 6 speed allison trans controllers 2006 through 2008. everything elses seems ok.
    Member jay p's Avatar
    Dec 2005
    update on this???
    2019 Sierra 6.2l
    2017 2500HD L5P
    2010 2500HD LMM (sold)
    2005 Harley Ultra Classic
    Very sorry guys, I currently don't have a V2 with BBL installed here, it is working ok with the older non BBL firmware. I'll get Paul to get one to me ASAP.
    Again, sorry I let this slip by.
    quick update, found another V2, upgraded it to BBL, and I have the exact same TCM read issue as you guys are having.
    I'll send the details to Paul.
  1. 2006 MAX no PE ?
    By fastjim455 in forum Gen III V8 Specific
    Last Post: January 8th, 2009, 05:59 PM
  2. COS for 2006 OS
    By MoTruck in forum Custom Operating Systems
    Last Post: July 9th, 2007, 02:07 PM
  3. Read posts in search...read tut..LM1 help.
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: March 15th, 2006, 02:00 PM
