Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Car Wont Idle And Runs Rich At Idle ( Tune Inside)
  1. #11
    Member TuneMaster's Avatar
    Try this one. If it is still rich correct your VE Table values.
  2. #12
    Nov 2007
    We took the stock ve tables and subtracted -50%. Is that not enough?
  3. #13
    If I was you I would go back to a stock VE Table. Subtract 40, 30 and 20 percent from the 400, 800, and 1200 rpm rows only. Do this as a starting point. Then follow the auto VE tutorial and dial the VE from there.
  4. #14
    Nov 2007
    What would a 408 tune do to a 347? Rich or lean wise. It is a similiar set up
  1. 98 cam only minor idle issues (log inside) HELP
    By bad6as in forum Gen III V8 Specific
    Last Post: April 9th, 2009, 10:56 AM
  2. Car Running Rich with Lean Plugs (Tune Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: March 26th, 2008, 03:58 AM
  3. CLSD tune runs great 30 min later rich at idle
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2007, 12:57 AM
  4. dyno tune now car wont idle
    Last Post: April 13th, 2006, 06:11 AM
  5. I cracked the 96 lb injector idle AFR!!!! Now it wont idle!
    Last Post: October 13th, 2005, 12:09 PM
