I was logging this morning (LTFT% vs. MAP vs. RPM). When I switched back and forth between the MAP and dashboard b, the numbers didn't seem to match. I had the cruise control on to keep me in the same FTC. On the dashboard, the LTFT for the left bank was reporting -4.7%. But, the LTFT for that same bank in the MAP was being reported as -2.3%. I checked highest and lowest reported values for that cell and they both said the same thing (-2.3%). Has anyone else noticed this? Is it 1/2 of the value on the dashboard for a reason? I thought it was odd because the other cells seemed right at a glance.
