Originally Posted by
Tony @ MPH
Sure Paul, I'd be happy to. We're having a bit of a hectic day here so it will be later this evening, Eastern time. But I'll definitely get to it this evening.
BTW, are there any known bugs pulling the knock retard PID from the PCM? As far as I could tell there are not. But I noticed this vehicle, which is 100% stock, gets a LOT of knock. Anywhere from 3 to 8 degrees and mostly at light/part throttle. But I can see the PCM is commanding an awful lot of timing, usually over 40 degrees. It seemed almost unbelievable how much it was knocking, or thought it was knocking.
