Results 1 to 4 of 4
Thread: help with gas pedal
    Oct 2006
    Default help with gas pedal
    sorry guys i am not on here often.but i just realy started tunning alot on my new truck due to the 01 being down for a while.
    anyway i am having problems with my tp sensor i can not get 100% throttle angle and when i just tune the key on i am reading 20.9% throttle angle i know something is wrong just don't know what are even where to start any help is greatly appreciated.
    Oct 2005
    What year truck is it and which TP PID are you logging?
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    he has a NNBS Silverado '08?. i havent got to mess with one of those trucks so i couldnt help him much over the phone..
    Oct 2005
    As has been suggested on PT.net, I would try logigng the ETC PIDs, not SAE.TP
    SAE.TP may be showing you % of 5V. So 85% would equate to 4.25V. Which likely represents WOT and can be confirmed by checking the blade position.
    You might have to switch to "General" scan mode for the ETC PID to work properly(Edit>Properties>Logging).
    The spring-determined position of the blade will be around 20% TP when the engine is not running. This is also why the engine starts chugging and bucking if you try to come to a stop in REP mode. 20% is too much air for idle.
  1. ETC Pedal Response
    By 05_Sierra_6.0 in forum Gen III V8 Specific
    Last Post: July 8th, 2017, 05:50 AM
  2. DBW pedal and TAC module differences
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: September 17th, 2009, 06:09 PM
  3. Accelerator pedal problems
    By JoakimMD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 21st, 2009, 11:49 PM
