Results 1 to 10 of 11
Thread: Cant use v2 control panel on pc
    Jun 2007
    Default Cant use v2 control panel on pc
    Hey guys, i have the flashscan 7.5 with the newest updates and my controller has the newest firmware available.
    I cannot get Efilive scan to see my v2.
    The pc can see the v2 when using the efilive explorer, but not with scan program.
    Also when i go to select v2 (hapi) in the properties it isnt there, just EFILive flashscan v2.5 and the others.
    Also when connected to pc, it doesnt say usb mode like it used too.
    Does anyone know of a way to get it to work.
    Jan 2005
    Welcome to the forum Clubsta.
    In order for the scan and tune tools to communicate to V2, EFILive Hapi must not be running.
    Jun 2007
    Hapi is not running, only when the explorer is open.
    I have v2.5 selected in the scan tool, but there is no option for v2.5(hapi)
    Jan 2005
    V2.5 is the correct selection. I'll be testing some pass-thru operations in a few minutes. Will let you know
    Jan 2005
    Only had one prolem with pass thru and it was with an odd combination of scan and tune tool sequences. Otherwise it worked perfect. Make sure EFILive Explorer and EFILive Hapi are not running and select V2.5 as the cable type and it should work.
    Paul - you have email on the way
    Jun 2007
    I can scan using laptop, it just wont let me access the v2 control panel in scan tool. It is always greyed out no matter what i am doing.
    Lifetime Member bobo's Avatar
    Nov 2005
    Quote Originally Posted by cLuBsTa
    Mine is like this too. I'd like to be able to go in and select some different pids for BBL.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    The V2 control panel (for BB Logging and A/D calibration) is not available once you have upgraded to V2.5 firmware.
    The PID seclection/setup for BB Logging is currently done by editing the file \Program Files\EFILive\V8\EFIlivE_Hapi\Config\Options.ini using Notepad.
    Hint: Look in the Readme.txt file in the \Program Files\EFILive\V8\EFIlivE_Hapi\Pid Descriptions folder for more information.
    This is only a temporary situation during the beta test phase. A Windows based PID/Vehicle selection option will be available for configuring black box logging.
    The A/D calibrations are now handled within FlashScan, as a standalone operation (no PC required).
    Regads
    Nov 2005
    Thanks for pointing out that readme file. I forgot to check the V8 folder for one after I unzipped everything.
    Regads
    Didn't see how to do it in the readme, but I gave it a shot....kinda looks like this-
    LLY A Pids:
    ; PID Caption Prec Units Op Factor Offset
    PCM,ECT, Coolant, 0,°F, *, 1.8, 32.0
    PCM,MAP, M'Fold, 1,psi, /, 6.894757,
    PCM,VSS, Speed, 0,mph, /, 1.609344,
    PCM,SPARKADV,Spark
    PCM,IAT, Intake, 0,°F, *, 1.8, 32.0
    PCM,MAF, AirFlow, 1,lb/m, /, 7.559873,
    PCM,TP, Throttle
    PCM,KR, Knock
    PCM,ENGOILP, EngOilP, 1,psi, /, 6.894757,
    PCM,MAINBPW, MnInjPW, 0,uS,
    PCM,MNINJTIM, MnTimng, 0,Deg,
    PCM,FRPDES, RailDes, 1,psi, /, 6.894757,
    PCM,FRPADES, RailAct, 1,psi, /, 6.894757,
    PCM,FTEMP, FuelTmp, 0,°F, *, 1.8, 32.0,
    PCM,TCVDES, VaneDes
    PCM,TCVPOS, VaneAct
    EXT,T1, T1, 1,°F, *, 1.8, 32.0
    EXT,T2, T2, 1,°F, *, 1.8, 32.0
    and Options:
    ECT Engine Coolant Temperature
    TCVDES Desired Turbo Vane POS
    TCVPOS Actual Turbo Vane POS
    MAP Manifold Absolute Pressure
    RPM Engine RPM
    ENGOILP Engine Oil PSI
    TP Throttle Position
    VSS Vehicle Speed Sensor
    IAT Intake Air Temperature
    FRPDES Desired Rail
    FRPADES Actual Rail
    MAINBPW Main Injection Pulse
    MNINJTIM Main Injection Timing
    FTEMP Fuel Temp
    MAF Mass Air Flow
    OBDSUP OBD Compliance
    AUXIS Auxilliary Input Status
    PTO Power Take-Off
    AD1 Analog Voltage - Connector 1
    AD2 Analog Voltage - Connector 2
    AD3 Analog Voltage - Connector 3
    AD4 Analog Voltage - Connector 4
    SW1 Input Status - Switch 1
    SW2 Input Status - Switch 2
    TEMP1 Temperature - Thermocouple 1
    TEMP2 Temperature - Thermocouple 2
    I'm going to bed. I'll test it in the AM.
    Quote Originally Posted by bobo
    No, that won't work. You can ONLY edit the Options.ini file. You can ONLY add PIDs to the Options.ini file that are listed in the relevant *.txt files in the Pid Descriptions folder. See the Readme.txt file in the Pid Descriptions folder for an example of how to add PIDs.
    For the Duramax's only a handful of PIDs are currently available. See the LLY-A_PIDs.txt file for a list of currently supported black box logging PIDs.
    The complete set of PIDs will be added further into the beta test.
    Don't forget to copy the Options.ini file to the [Config] folder in FlashScan.
  1. Can Not Display Rr Control Panel...
    By TFZ_Z06 in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 4th, 2008, 05:37 AM
  2. LC-1 F-Body Gauge Panel
    By Beer99C5 in forum Lounge
    Last Post: January 17th, 2007, 04:47 PM
  3. My first EFI Panel w Custom OS toggle
    Last Post: January 14th, 2007, 12:46 PM
  4. Switch Panel
    By white2000ta in forum Black Box Logging
    Last Post: June 14th, 2006, 01:11 AM
