Results 1 to 10 of 10
Thread: 98 to 99 pcm swap question please help
    Dec 2007
    Question 98 to 99 pcm swap question please help
    Ok ive decided to start swaping my 98 pcm to go to the 99 pcm and so far ive got 4 wires that the 99 have no spot for! Does anyone know where these wires are supposed to go??? On the 98 its labeled pin 24 Blk/wht-sensor ground jumper. Pin 55 DK GRN/WHT- VSS OUTPUT SIGNAL. Pin 69 BRN-EVAP PURGE VACUUM SWITCH SIGNAL. Pin 75 GRY-LEFT AND RIGHT FUEL TANK LEVEL SENSOR GROUND. These are the explanations that my 1998 manual gives me for these wires but i have a wiring diagram i bought for a 1999 corvette offline and i can't find a spot for them, please help me or call my if you wish. 336-225-7932. Thanks Adam Calley.
    Lifetime Member driver456's Avatar
    Quote Originally Posted by Adam Calley
    Pin 24 Blk/wht-sensor ground jumper(DISCARD)Pin 55 goes to red plug pin 50.Pin 69 not sure.Pin 75 goes to BLUE PLUG pin 23
    Dec 2007
    OK before i make a huge mistake here someone please clear this up for me. My 98 manual says c1(connector 1) is the red connector and c2 (connector 2) is the blue connector. and the 99 is totally opposite right? I think im thinking about this way to hard but just clear that up for me. thanks Adam
    Feb 2006
    You are correct. It sure makes it confusing.
    Al
    Dec 2007
    Default yea it does
    Thank you man i appreciate it, im glad im not the only one gettin confuesed, do you have any idea where pin 69 goes its the evap control wire or am i not going to have the evap system working anymore after this swap?
    Also on the 97-98pcm pin 44 on the BLUE plug"DISCARD"(Fuel level sensor's 5.0 volt feed)
    Dec 2007
    Default why
    why do you discard pin 44, fuel sender 5 v feed, cause i found the spot with the right circuit number to put it?
    Jun 2007
    It is an extra 5 volt feed for the 97 fuel level sensor, now, you are retaining the 97 fuel sensors in your car but the way the new PCM will read your fuel level is different, so that 5 volt feed is no longer needed.
    FWIW i did not hook that 5 volt feed up in my car, and my fuel gauge works perfectly
    WWW.EFIAlchemy.com
    Quote Originally Posted by eurospec1
    I was going to tell him to pm you because thats where I got my info from............Paul
    Dec 2007
    ok i see. well thanks for the info i really appreciate it thanks agian!!!
  1. TC swap
    By harascho in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2009, 05:57 PM
  2. Trans swap - GenIV pcm T42 question
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 24th, 2008, 06:36 PM
  3. '02 Corvette gear swap question
    By Patches in forum Gen III V8 Specific
    Last Post: July 10th, 2007, 12:05 PM
  4. Swap 06 pcm for 05 pcm??
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 30th, 2007, 07:49 PM
  5. swap my '02 LB7 for an '04 LLY?
    By jerjoek in forum Duramax LLY
    Last Post: September 19th, 2006, 02:11 PM
