Results 1 to 3 of 3
Thread: WBO2 controller
    Jan 2008
    Default WBO2 controller
    I am new to EFi live and looking for a WB02 sensor setup. The Manual says I need a 0-5v AFR output from the WB controller.
    I am Struggling to find one where I am, and was wondering if this would do the job.
    http://www.precisionrace.co.za/content/zeitronix.html
    Would the AFR outputs work with the flashscan interface.
    Looking forward to learning more about tuning from you guys!
    Im sure you will be hearing from me quite often.
    Happy motoring!
    Nov 2006
    Input/Output range
    Lambda 1.43 to 0.64 Wideband
    AFR 21.0 to 9.5 Wideband
    Vacuum 650 mmHg
    Boost 2.4 BAR
    EGT 200 C - 1200 C
    Analog Wideband Output 0 - 5V
    Throttle Position 0 -100 %
    RPM 0 - 14,000
    User Input 0 - 5V
    looks like it will.
    and it is priced nicely.
    Jan 2008
    Thanks for the reply. Spent so much time breezing over units, that I missed that bit. I supposed I helps to read closer doesn it.
  1. How do you log WBO2 lambda instead of AFR?
    By waveoff in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2009, 08:03 AM
  2. Installing wbo2
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2008, 11:20 AM
  3. V2 controller
    By twinki025 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2007, 05:27 PM
  4. wbo2 opinions
    By warscout2 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 30th, 2007, 04:16 AM
  5. Which WBO2 would work the best for......
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 27th, 2006, 03:41 PM
