Results 1 to 10 of 14
Thread: Turning EGR Off Higher EGT's?
    Dec 2007
    Default Turning EGR Off Higher EGT's?
    I have done some research on EGR and the general concenus out there is that if you turn EGR off that EGT's will actually climb? The argument is that you have more oxygen and higher cylinder temps due to no EGR cooling everything down. If this is true does anyone know how Much? If we are marginal to begin with due to a tune will this put us over?
    2006 Silverado LBZ Stock.
    Sep 2007
    You know i changed a tune by JUST the egr setting (it went from on and i turned it off) and i noticed LOWER EGT's cruising down the freeway and in town believe it or not.
    Jan 2006
    peak EGT's should not change any. The EGR is disabled at higher power output requirements.
    Custom Tuning Services
    May 2007
    When cruising egt's will be lower.
    I encourage all to block the egr, disable the egr, and shut off all of your egr DTC's.
    Your engine will thank you.
    '07 LBZ Classic, BW S464 Turbo, EGR deleted, 3" IC piping, Trans-go, ATS 5-star converter, stock clutches
    Jan 2008
    im new to this whole egr thing, on my lmm stock motor but efi live tune i turned the egr off, im not sure i did it correctly because as soon as i put the truck in drive it idles really low and wong go its almost like its limping or something and then as i think it "warms" up it drives really really well, the pickup is amazing but i just dont know why im having this problem..its almost like it has to warm up or something and then its fine, so i turned the egr back on to the stock settings and now its fine but its obviously slower, what can i do to the egr? is there something called a blocker plate? or do i take the thing off? thanks for the help
    Senior Member camcojb's Avatar
    Dec 2007
    Quote Originally Posted by LMMpioneer932
    there's a blocker plate, and it's a real bear to install. If you turn it off in the tune you get the same thing as the blocker as long as you're running no more than 28 psi or so of boost. Beyond that it will blow the egr valve open, which is why the blocker plate came to be. How did you turn off your egr? Can you copy your egr parameters in the tune?
    Jody
    Jan 2008
    well im not sure if i turned it off correctly but it definlty improved the power by a shitload.. im gonna have to find a way to get that blocker plate installed but i hear everyone is having problems with getting it off. i might have done it wrong because at first it seems to go into unoffical limp mode for about 15 seconds and then its like it warms up or something and its fine, absolutly fine which is wierd no trouble codes or nothing i ran it pretty hard just in case and it seemed totally fine. but im really worried about the beginning because it definlty doesnt seem right that it should do that at the beggining, so i turned put the stock settings back and its 100% fine now im wondering what that is tho at the beggining it does seem right at all, and i want to know how to really turn it off, cuz i think i did it but not completly and thats why i had the problem
    Dec 2007
    that's why I asked what egr parameters you used in your tune. I had it turned off in one tune and on a restart it would act like it was out of gas, jerking forward if in drive, only for a few seconds and then was fine. Didn't do it every time but started to be more and more common. I switched my egr parameters as below and the problem stopped and has never returned.
    Jody
    Jan 2008
    ok thanks man il try that, i think you were dealing with the same thing i did. thanks for the fix!
    Dec 2007
    please let us know how it goes. It stopped my issue.
    Jody
  1. Sparks Higher than we are asking
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: April 22nd, 2010, 07:02 AM
  2. P12 Turning off COT
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 10th, 2010, 02:58 PM
  3. What happens when I set a value higher than the tables know?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 1st, 2009, 02:32 AM
  4. more air = higher compression?
    By jchev502 in forum Vortec V6/V8 Specific
    Last Post: July 19th, 2008, 09:21 AM
  5. turning a 60 to a 60e
    By bob94z28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 14th, 2007, 05:29 AM
