Results 1 to 10 of 14
Thread: Best way to monitor clutch slip
    Aug 2006
    Default Best way to monitor clutch slip
    What pid would best monitor this?
    I figure watching the rpm is one way.
    Is there anything for input shaft speed?
    Any suggestions to monitor this?
    Lifetime Member mistermike's Avatar
    Dec 2003
    VSS and RPM should be at a fixed ratio in gear. If they drift apart, the clutch is slipping.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Aug 2006
    Quote Originally Posted by mistermike
    anyone else?
    Create a calc pid for this: Trans Input RPM = VSS * 336 * GR / TD
    where:
    VSS = vehicle speed [MPH]
    TD = tire diameter [inches]
    GR = overall gear ratio = trans ratio * axle ratio
    Quote Originally Posted by example
    T56 in 3rd gear (1.30), thru 3.46 axle at 70 MPH on 275/40R17 tires
    TD = 2 * (275 * 0.40) / 25.4 + 17 = 25.66 inches
    GR = 1.30 * 3.46 = 4.498
    Trans Input Speed = 70 * 336 * 4.498 / 25.66 = 4123 RPM
    Then in your log you can compare engine RPM to Trans Input RPM, or you can create a calc pid for RPM / Trans Input RPM.
    This is what Mr.Mike is saying to do.
    Joe
    Aug 2006
    where:
    Joe
    sent pm
    Default Trans Input Speed calc pids (4.10 axle, 26.2" tire)
    Replace calc_pids.txt with the following [see attached file]
    (be sure to first save your existing calc_pids.txt):
    Code:
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter  Value            Description
    VERSION     7.1.1            File version
    DECSEP      .                Decimal separator used in this file
    # Units
    # See sae_generic.txt for more information on the *UNITS section
    *UNITS
    #Code     System     Abbr     Description
    None      None       ""       "No units"
    inch      Imperial   "in"     "Inches"
    # Add slot definitions here
    # See sae_generic.txt for more information on "SLOT" formats
    #Units             Low          High      Fmt  Expression
    *CLC-00-080
    inch               0.0          60.0      0.2  "26.2"
    *CLC-00-090
    factor             0.0          10.0      0.2  "4.10"
    *CLC-00-101
    rpm                  0          8000      0.0  "{SAE.VSS.mph} * 336 * {CALC.AXLE} * 2.66 / {CALC.TIRE}"
    *CLC-00-102
    rpm                  0          8000      0.0  "{SAE.VSS.mph} * 336 * {CALC.AXLE} * 1.78 / {CALC.TIRE}"
    *CLC-00-103
    rpm                  0          8000      0.0  "{SAE.VSS.mph} * 336 * {CALC.AXLE} * 1.30 / {CALC.TIRE}"
    *CLC-00-104
    rpm                  0          8000      0.0  "{SAE.VSS.mph} * 336 * {CALC.AXLE} * 1.00 / {CALC.TIRE}"
    *CLC-00-105
    rpm                  0          8000      0.0  "{SAE.VSS.mph} * 336 * {CALC.AXLE} * 0.74 / {CALC.TIRE}"
    *CLC-00-106
    rpm                  0          8000      0.0  "{SAE.VSS.mph} * 336 * {CALC.AXLE} * 0.50 / {CALC.TIRE}"
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code                      PRN  SLOT         Units            System           Description
    CALC.TIRE                  F080 CLC-00-080   inch             Testing          "Tire diameter"
    CALC.AXLE                  F090 CLC-00-090   factor           Testing          "Axle Ratio"
    CALC.TIS_1ST               F101 CLC-00-101   rpm              Testing          "Trans Input Speed 1st Gear"
    CALC.TIS_2ND               F102 CLC-00-102   rpm              Testing          "Trans Input Speed 2nd Gear"
    CALC.TIS_3RD               F103 CLC-00-103   rpm              Testing          "Trans Input Speed 3rd Gear"
    CALC.TIS_4TH               F104 CLC-00-104   rpm              Testing          "Trans Input Speed 4th Gear"
    CALC.TIS_5TH               F105 CLC-00-105   rpm              Testing          "Trans Input Speed 5th Gear"
    CALC.TIS_6TH               F106 CLC-00-106   rpm              Testing          "Trans Input Speed 6th Gear"
    Of course, if you have other calc pids in your existing calc_pids.txt, you need to copy the 3 sections above (colour coded) to your calc_pids.txt without disturbing your existing definitions.
    Edit History:
    0. initial post.
    1. changed MPH to RPM.
    2. changed SAE.VSS to SAE.VSS.mph.
    3. changed gauge/chart high to 8000.
    After copying the calc_pids.txt file do this:
    - start the scantool,
    - open your log file,
    - goto the PIDs F8 tab,
    - select the tire and axle calc pids shown in the attached pic,
    - select whichever other TIS pids you want,
    - press the replot button,
    - on the dash tab, add the TIS pid(s) to your chart display
    - press the replot button.
Name:	Trans Input Speed.png
    Oct 2003
    I guess you are referring to what I might call "runaway" which is slip after engagement? It seems this is how many LS clutches overheat and first fail > in third gear near max torque?
    PowrMax Performance
    100 mm PowrMAF
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    where:
    Joe
    If the PID is calculating Trans Input Speed, shouldn't the PID be RPM instead of MPH in the calc_pids file?
    I think you need to add mph to {SAE.VSS.mph}. The numbers looked high without it.
    Quote Originally Posted by Ninety8C5
    Ah, yes RPM not MPH, slipping brain...
  1. TCC Slip when showing fully locked.
    By mhburton in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 28th, 2010, 10:14 AM
  2. Measuring Transmission Slip
    By BlkMax in forum Allison 5 & 6 Speed
    Last Post: December 18th, 2009, 02:23 AM
  3. Clutch Relearn?
    By Chalky in forum Gen IV V8 Specific
    Last Post: March 16th, 2009, 01:08 PM
  4. DTC P1870 & TCC slip table
    By tblu92 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2007, 01:11 PM
  5. Car dies when i hit the clutch...Little help plz
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2006, 11:32 AM
