Results 1 to 5 of 5
Thread: Help Needed.
    Senior Member SV8346's Avatar
    Nov 2007
    Default Help Needed.
    Ok i'm a little confused, i read somewhere that with BBL we cant log GM.DYNCLAIR_DMA if this is the case is there something else that i can log so as to be able to link my logs to the High/Low spark tables. At the moment any BBL i do and then check them back against my spark tables, no matter where abouts in the air flow range i am it only links to the 0.08 grams/cylinder column.
    2016 RG Colorado 2.8TD
    Jan 2004
    Why not take the laptop out and just do some regular pass through logging?
    **edit** Maybe I misunderstood. Did you mean that with the BBL firmware that GM.DYNCLAIR_DMA can't be logged at all, even in pass through?
    Nov 2007
    with the laptop in pass through it will log no problems. But if BBL logging is available then i would like to be able to log it and link it to the timing tables. Whats the point in BBL if it detects knock from to much timing yet you cant do anything about it cause it wont link to the timing tables.
    Understand your request and its quite reasonable. However, the software (and PID definitions) are still in a state of "potential change". It takes a *lot* of work to enter scaling data for many PIDs.
    Once the BB logging firmware is stable, the PIDs will be added. I don't want to go add them all in now only to find there is a problem that requires them to be modified again.
    Regardless, the "smarts" to log _DMA PIDs has not been coded for BB Logging yet.
    I am away (summer holidays - yay!) for the next two weeks. I intend to spend a few quiet nights watching the sun go down and doing data-entry on the PID selections. So when I get back (Start of Feb) there should be a complete (or almost complete) set of PIDs for BB Logging. That excludes _DMA PIDs; support will be added for BB Logging of _DMA PIDs during Feb.
    Nov 2007
    no worries mate, thanks for the reply at least i know something for it is coming, thats good enough for me so i'm happy to wait for it. Enjoy your holiday.
  1. TCM OS needed
    By giesbrecht in forum Allison 5 & 6 Speed
    Last Post: March 4th, 2010, 08:43 AM
  2. E67 ECM and T42 TCM Help Needed
    By finishline in forum E37, E38 & E67 PFI ECM's
    Last Post: February 7th, 2010, 07:04 AM
  3. Help needed using DVT on a t42
    By MyM8V8 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 10th, 2009, 07:12 PM
  4. Key needed????
    By v8vegaman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2007, 04:16 PM
  5. DTC Help Needed
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: August 8th, 2007, 01:39 PM
