Results 1 to 10 of 16
Thread: Driver problem -- WinXP SP2
    Jan 2008
    Default Driver problem -- WinXP SP2
    This is for a customer of ours. I have tried everything I could to address the problem to no avail.
    Here are the facts as I know them.
    1. FSV2 unit itself is fine. We test each of them before shipping them out.
    2. Unit works fine on Vista machine.
    3. Unit refuses to work properly on XP SP2 machine.
    4. Drivers fail attempting to install a file that does not exist in the driver package on the EFILive download page (I forget the name, but it is clearly part of *A* FTDI package, just not *THIS* FTDI package)
    5. We tried uninstalling the driver through device manager.
    6. We tried just "updating" the driver through device manager.
    7. We tried uninstalling through control panel (which says it was successful) and then rebooting/installing FSV2 and manually pointing it to the drivers (unsuccessful)
    8. We tried FTClean from FTDI's website
    9. We tried manually deleting .INF and .DLL files from windows/system32/drivers.
    I just can't figure out how to excorcise the driver ghost on this laptop. Any "nearly" successful attempt at getting the new drivers in always results in Windows asking for the disk with the FTDI drivers on it, because it wants a file that does not exist in the driver package.
    Does anyone have any tried and true methods that work every single time to resolve this problem? Is the driver package in the downloads section just a driver update or is it 100% complete? I have not checked the INF files to see if they rely on some other file that already exists or should exist due to prior install or just as a native part of the OS.
    Oct 2006
    2006 Trailblazer
    Jan 2008
    Hmmm, definitely some good info in there, but I am still not sure where to go with the customer at this point.
    The problem is, even when we try to install the drivers from EFILive's download section -- both downloaded by the customer, and also emailed TO the customer from me -- there is a missing file that XP tries to install. It insists that the files for the FTDI driver are not complete.
    It must be getting this information from an old driver that was installed. I know the FTDI USB->SER components are common. There is even one in the device I use to animate my Christmas lights So it's entirely possible to get a bad FTDI driver installed somehow but what really stumps me is the thread you posted says that EFILive has a unique PID. Therefore Windows should *not* be attempting to use an old or different driver, unless perhaps the customer manually installed a driver that he should not have.
    Nonetheless, add/remove programs now does not show any FTDI drivers installed and we can't seem to find out how to remove the old FTDI drivers. About the only recommendation I can offer at this point is to do a fresh install on the box -- unless someone has a tip that will save him a lot of time and effort.
    I can usually work these kinds of things out on my own machines and figure out where the rogue .INF file is hiding and nuke it and be on my way, but it's nearly impossible to do over the phone.
    Oh, we could not get FTClean to work either -- on my XP machine it says Access Denied when it tries to write the INF file for the uninstaller and on his machine it passes through successfully but the uninstaller never runs.
    Maybe if there's something simple I'm missing there we can get FTClean to run properly and nuke the old drivers entirely.
    Oct 2006
    I think the key thing in the post was not to be on the internet when doing the Install because Windows tries to download the FTDI file from the internet and it is the wrong one .
    Someone more advanced than I in EFILive may have to help you on this I just saw the Post and thought it might help .
    FTDI is usually a Serial to USB chip driver .
    I would suggest "reg-cleaner" but don't know if that would help !
    Start>Run>"regedit" , will bring up "registry editor" do "Search" for FTDI remove entries , be careful can cause bad results , maybe do a back up of registry first (export) and do "Search" all drives and remove FTDI found there .
    2006 Trailblazer
    Jan 2008
    That is good info for sure. Unfortunately his laptop is not connected to the internet at all. We had to download drivers and exchange emails on another computer and then put the info on a USB key and take it to the tuning laptop.
    Thank you for following up though, I appreciate any and all help on this one at this point.
    I would even accept voodoo and chicken sacrifices as a viable solution at this point.
    Oct 2006
    Someone will see this post and comment with the correct answer , don't give up just yet !
    Step back and have a few .
    2006 Trailblazer
    Jan 2008
    Thanks tunedbyGM. I actually just spoke to the customer again and he is going to come in and post anything that he has to add to hopefully help push this thread along.
    I am lucky that he is technically competent so I don't feel as bad about recommending a reinstall, I just hate to tell him to do that because of the time commitment on his part.
    I would say about 8 times out of 10 when I've had an issue like this in the past I can find the .INF file in \windows\system32 and \drivers just based on the name. But a lot of that is just based on me knowing what files Windows was likely to have installed, what files were installed by other manufacturers on the machine, and trying to identify a filename that sticks out as being an FTDI file.
    About the only other thing I could think to do is to do a *text* search for the VID and PID across the hard drive. I think almost certainly if we can find the .INF file and delete it, Windows will no longer attempt to automatically install based on the old information and will take all the new information properly.
    VID_0403 should be the manufacturer ID.
    Oct 2006
    I found a .sys but no .inf for FTD2xx.sys in C:\WINDOWS\System32\drivers , maybe that is it ?
    Back up before removing .
    2006 Trailblazer
    Jan 2008
    Hmmm... we are still getting an error while installing the drivers, even when installing right off the CD.
    "The system cannot find the file specified."
    Oct 2006
    The FTD2xx.INF is located in the EFILive folder C:\Program Files\EFILive\V7or 7.5 which ever you have \Dirvers\FlasScan\Win-98-Me .
    FTD2xx is the FTDI lookup .
    .INF is a setup information file .
    Make sure the FlashScan is not plugged in before installing the driver .
    2006 Trailblazer
  1. usb driver problem! please help
    By byler900f in forum FlashScan V2
    Last Post: May 30th, 2009, 11:22 AM
  2. Help w/ installing driver for Lc-1
    By 99TransAmls16spd in forum General
    Last Post: June 24th, 2008, 06:44 AM
  3. Driver Problem
    By Duramax 6.6L in forum FlashScan V2
    Last Post: June 22nd, 2008, 03:56 PM
  4. efilive v2 driver
    By blackbeast ss in forum Gen III V8 Specific
    Last Post: March 13th, 2008, 09:57 PM
  5. Efi Driver
    By kws808 in forum General (Diesel)
    Last Post: September 6th, 2006, 07:11 PM
