Results 1 to 10 of 11
Thread: Post Injection
    Dec 2007
    Default Post Injection
    I just recieved my EFI Live and just starting to play with it and have some questions regarding the post injection.
    1. What does post injection actually do?
    2. Is it strictly emmisions?
    3. How much fuel is actually injected and how badly does it hurt fuel economy.
    I read somewhere that if you put 1 in Table B1021 it will eliminate the post injection? Does that mean you actually put 1 in every box of the table?
    Thanks guys.
    2006 Silverado LBZ Stock.
    Yes, post is used for emissions, it does not make more power as it happens after the 'bang'.
    They use it to control the DPF temps, it certainly does not help MPG!
    If your DPF is still in place then leave the post injestions alone.
    Mar 2007
    if the truck in question is the one in his sig its an LBZ and there is no DPF... turn it off and no worries. egts will be a little lower (that I noticed with mine). other than that, no lossed that I have noticed... I dont have my laptop handy with table numbers but I zeroed out the post injection tables and I believe the multipliers as well.
    Dec 2007
    Thanks Guys, and sorry the truck is a 2006 LBZ so I don't think I have a DPF. Are the Tables B9301 and B9302? Post injection # 1 is already at zero. Do we just type into the table and save?
    I missed that too, LBZ the post injections are non functional anyway, but it's all in the ECM anyway.
    Mar 2007
    are you saying that the post injections are non functional in that they dont do anything productive but the injections happen... or that they are just "dead" tables that dont affect anything because the injections dont happen?
    Dec 2007
    I believe they are also used to keep the temps higher for the cat.
    08 Chev Crew, LMM, MBRP Tback, EFILive.
    Mar 2007
    well I certainly dont need that function anymore lol
    Feb 2011
    Did you notice any MPG increase?
    Thanks!
    Quote Originally Posted by tinman22 View Post
    Mar 2007
    nothing I really noticed. I want to believe that I gained a quarter to half mpg. but fluctuations tank to tank can easily be that much different unless you do the exact same driving day to day. and that I dont do
  1. no pilots, no post injection
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 4th, 2012, 06:55 PM
  2. Disabling Post injection on LBZ
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2009, 11:00 AM
  3. Eliminating post injection
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 10th, 2007, 12:08 PM
  4. Cranking Injection Qty Map
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 3rd, 2007, 08:54 AM
  5. injection timing
    By 02gmcwaldoch in forum General (Diesel)
    Last Post: March 18th, 2006, 07:43 AM
