Results 1 to 3 of 3
Thread: 2nd start runs lean
    Jan 2007
    Default 2nd start runs lean
    Hi All,
    I've noticed that after I've been driving a while, if I stop and then start the car again in say 20mins, it runs lean for a long time.
    Is this because the motor will have kept heating up and therefore effecting the fueling on restart? (I think I explained that properly ).
    Is this where I need to have A0008 populated?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Aug 2006
    I think it is that, and also heat soak in the IAT.
    Jeff
    Jan 2007
    Thanks Jeff
    Howard
    DUCT TAPE.
  1. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 12:44 PM
  2. Lean cold start COS3.
    By onfire in forum Custom Operating Systems
    Last Post: July 18th, 2009, 01:10 AM
  3. Lean Cold Start Problem
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: May 14th, 2008, 10:52 AM
  4. Lean Start Problem with pre-2003 OS
    By hpcubed in forum Custom Operating Systems
    Last Post: April 1st, 2008, 10:54 AM
  5. Lean at start up then rich at Idle
    By pwilson22000 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 12th, 2006, 07:19 AM
