- How do you reset TAPS?
- Does reseting TAPS engage Fast Learn?
- Does reseting the TAPS also reset Defuel?
- How do we limit Defuel? I am getting a hard Defuel between 3rd and 4th.
Thanks in Advance
Thanks in Advance
2006 Silverado LBZ Stock.
Currently I think the only way to reset TAPs on the 06+ is to flash your stock program back to the TCM. It appears to clear TAPs.Originally Posted by petestoy
Yes
No, defuel is commanded of the ECM by the TCM.
I think you can turn defuel off using D5197. As far as reducing, but not eliminating defuel, I've been told lots of logging...
But I'm not an expert.
