I have DSP5 installed on my truck and I got on the throttle this morning while my truck was at about 127deg F. My fuel volume for WOT is set to 100mm^3. I have the B0729 table set to 60mm^3 over the whole table. The B0730 table is set to 162deg F. Since the ECT was below 162deg F. I figured I should only see a max of 60mm^3 or so of fuel. I saw 99.9mm^3 on the FUELQ_THR_DMA and 98.6mm^3 on the MAIN_DMA PIDs. Am I wrong or should this table limit the fuel volume for all DSP positions to 60mm^3 until the ECT reaches 162deg F?
TIA.
BTW I'm running 7.5.3 with the latest Calibration files that include the idle timing tables and I am beta testing the V2 hardware and have the Jan 07, 2008 updates installed.
