Results 1 to 10 of 10
Thread: Laptop
    Oct 2006
    Default Laptop
    Just tuned my laptop , not really , just added a Core Duo processor to it .
    The Lenovo I have uses the same Mianboard for different Intel processors , I can still slap in a Core 2 Duo when they come down in price (more than I paid for the laptop) .
    More power !
    2006 Trailblazer
    Nice man, I have a Core2 Duo in my HP Pav 9500 laptop, and its fast! I know you said you run Linux, so Im betting its crazy fast, Im running Vista Ultimate x64 and its fast as is. Just be careful with a bigger CPU, you might shorten your battery life...
    Oct 2006
    Quote Originally Posted by ScarabEpic22
    Good point .
    The Celeron M was a 28w and the Core Duo is 31w , not a lot , but probably cut a few minutes off the battery time .
    Jesse got you those P10 TB files yet ?
    2006 Trailblazer
    Junior Member Jared Duramax's Avatar
    Feb 2008
    i got to do something with my laptop its so slow i think im just gonna add more ram to it. do you have any other suggestions
    Jared
    2003 GMC Sierra 2500HD LB7
    285/75R16 BFG AT, Prodegy brake controller, Bilstine Shocks, Tierod sleves, Pitman and Idler supports, 5" Magnaflow Turbo Back, PPE Boost Valve, Phantom II Boost and Pyro on Pillar, BD Manifold. EFI LIVE V2 By SoCal, EDP Twin Lift Pump's, Suncoast IV 1056, Billet Input Shaft, Merchant Automotive Pump Rub Kit
    Member #3 of NC Dmax's
    Lifetime Member Garry's Avatar
    Jun 2006
    More RAM usually helps any Winslows environment ... depending on how long it has been installed, and how many programs were installed over time, a fresh install might also be helpful ... maybe pick up a larger HD, that way you can keep the old one for reference ...
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Oct 2003
    Interesting.
    I have numerous laptops and and wonder if EFIlive can use, or requires much in terms of speed/RAM? The E-38s sure are fast compared to previous PCMs.
    I have a few legacy Amrel Rocky military laptops set up for tuning. They are 800mhz P111s with 384 ram (XP) and they have basically nothing other than EFI on them. When watching "Task Manager" There is no apparent limitation when using these, vs newer LTs -logging with wideband.
    With EFILive V2 and later PCMs what is the threshold?
    PowrMax Performance
    100 mm PowrMAF
    Feb 2008
    ill have to give that a try im not so good with computers
    Jared
    Oct 2006
    A good place to visit is www.tweakxp.com there are some good tweaks for XP and maybe Vista .
    Cutting down services that are running and not needed speeds up Winders .
    Making a Tuning Profile with Services turned off makes a good improvement at no cost .
    2006 Trailblazer
    Also TuneUp Utilities has a great software package (have to buy it though) for speeding up the windows environment plus some other neat utilities.
    And no, havent heard a peep about the new P10 files. Right now Id rather get the 06 P12 ones fully done...
    Oct 2006
    2006 Trailblazer
  1. on the way but no laptop
    By dt.2448 in forum General (Diesel)
    Last Post: January 8th, 2009, 02:56 PM
  2. Need Laptop
    By jorge in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2008, 04:54 AM
  3. Laptop Died
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2007, 09:12 AM
  4. How to connect LC-1 to Laptop...
    By BlueSLPCamaro in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2007, 02:11 AM
  5. laptop requirements?
    By articSS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2007, 09:28 AM
