Which PIDs are you using to log MPG?Originally Posted by kdubbz
I use the following: (I don't know if others have changed it)
{SAE.VSS.mph}/({GM.INJFLOW.lbpm}*{GM.IBPW1}*{SAE.RPM}*4/6250)
If it helps any..
-Adam Chant
Tune it or lose it!
2007 Saturn SKY 2.4L Automatic - E67
EFILive Tuned
Originally Posted by swingtanExcellent! Eagerness just went up a notch or two......Originally Posted by Blacky
Keep up the great work guys!
I use the same one MPG = {SAE.VSS.mph}/({GM.INJFLOW.lbpm} * {GM.IBPW1} * {SAE.RPM} * 4 / 6250 )
yea, what does 4 and 6250 mean in that equation?
4 = stroke ??
6250 = ??
Or better yet does this apply correctly for every vehicle or are there application specific details like with the HP CLC PID's?
-Adam Chant
Tune it or lose it!
EFILive Tuned
Not quite so simple... see this thread: showthread.php?t=1667&highlight=economy+pidOriginally Posted by scdyne
4 = 8 injector spray events every 2 crank revolutions
6250 = 6.250 lbs/gal [gasoline] * 1000 ms/s.
Duh! I knew that.. shhh. don't tell anyone I do this for a living..
-Adam Chant
Tune it or lose it!
EFILive Tuned
Calculated PIDs will not be user defined for FlashScan. FlashScan will only support a small list of "useful" pre-defined calculated PIDs. Who decides what is useful? Vote now...Originally Posted by Blacky
The reason the BB logging calc PIDs list will be limited is that FlashScan is running a 40MHz 16 bit CPU with software floating point libraries. Compare that to a 1GHz 32-bit Pentium with a hardware FP unit. The Pentium has probably 500 times more computing power.
Nothing will prevent you from using any other calc PIDs you like in pass through mode - just as you can now. It's just those other calc PIDs won't be available during BB logging.
I guess also... If the PIDs required for the CALC PIDs are included in the log they can be added afterwards anyway (when you have the log open in the Scan Tool).
Andrew
EFILive Crew
