Thread: Throttle area conversion from 78mm to 90mm.
    Nov 2007
    Default Throttle area conversion from 78mm to 90mm.
    What is the correct Throttle Area Conversion for a 90mm TB? I think stock it is .2xx. I was running .320 but I read it was .330 some where else. So what is the correct number to put in that table? I don't have the table number in front of me but I can post it up later if no one knows what I am talking about.
    Brett
    Sep 2003
    This was in another post about resizing TB. I don't remember which and can't find it right now.
    Nov 2007
    The attachment won't open. It says it is corrupted. So if you could find the number I would really appreciate it.
    Thanks,
    Brett
    Sep 2003
    According to the spreadsheet the increase should be 133%.
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    I used .0330 for 402 ci and .0355 for 427/441. I think all you are really doing is cracking the TB blade for idle., but it works if you need it.
    PowrMax Performance
    100 mm PowrMAF
    Nov 2007
    Thanks. That is what I was looking for. I actually think it was one of your posts that I was reading that gave me the .0330. I am running a pretty big cam for my 383 so it is demanding air. I will mess with that and see what happens.
    I will also do the math for 133% and see what that comes up to.
    Thanks guys.
    Brett
  1. 78MM ETC to 90MM TB - which scaler???
    By J-Rod in forum General (Petrol, Gas, Ethanol)
    Last Post: July 17th, 2009, 05:12 PM
  2. Throttle Body Area Scalar
    By finishline in forum Gen IV V8 Specific
    Last Post: August 24th, 2007, 02:05 PM
  3. For ETC tb's; Interesting observations regarding ETC throttle area conversion
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 16th, 2006, 04:03 AM
  4. Part throttle shift table conversion?
    By 67SS509 in forum General
    Last Post: January 16th, 2006, 01:51 PM
  5. Electronic throttle control conversion for the F-Body?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2005, 08:02 AM
