Today I placed my order for a transgo HD2 shift kit and other goodies. I allready have both servos, Soooooooo I have read that you need to disable adaptive shift learning after you install a shift kit, is this true? I read that you zero out your shift times, which disables the learning. I have also read that if you don't it will cause your shifts to soften over time. Has anyone else done this?
