Results 1 to 4 of 4
Thread: Disable adaptive shift learning after Shift Kit Install
    Jan 2007
    Default Disable adaptive shift learning after Shift Kit Install
    Today I placed my order for a transgo HD2 shift kit and other goodies. I allready have both servos, Soooooooo I have read that you need to disable adaptive shift learning after you install a shift kit, is this true? I read that you zero out your shift times, which disables the learning. I have also read that if you don't it will cause your shifts to soften over time. Has anyone else done this?
    Dec 2004
    from memory set all shift times to zero..(ls1)
    Oct 2006
    Yep , what he said . Zero (0)
    2006 Trailblazer
    Yes, this will prevent the adaptive learning algorithm from detecting that the shifts are firmer due to means other than the algorithm itself, and then trying to soften them.
    The shift kit is calibrated to give a firmer shift based on mechanical modification rather than algorithm looking up modified tables.
  1. Adaptive Learning
    By EVI in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: October 1st, 2011, 02:54 AM
  2. Adaptive Shift Times 4l80e + HD2
    By 2500ak in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 26th, 2010, 09:22 AM
  3. Unable to view adaptive shift cells
    By LBZRCKS in forum Allison 5 & 6 Speed
    Last Post: July 18th, 2008, 07:30 PM
  4. Shift Times, Line Pressures, Adaptive Learning -- AGAIN!
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 16th, 2008, 12:09 PM
  5. adaptive shift learning
    By dbaxter_ss in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 5th, 2005, 07:33 AM
