Can I install EFI live for XP and 2000 on a Vista laptop and then download the driver upgrade? I've had problems with corruption. If you've done this, can you help? Thanks.
There are no problems running EFILive on Vista, both x86 and x64 versions. I have it on my HP dv9575 with Vista Ultimate x64 with no problems. There are proper x64 bit drivers included, just install Vista then download the EFILive installer and install it. When you plug your FS in it should just find the drivers, otherwise they will be in the Program Files[if 64 bit then Program Files (x86)]\EFILive\V7.5\Drivers\FlashScan\Win-2K-XP-Vista\
No problems on Vista Ultimate here. Downloaded the 7.5.3 code, installed it, installed the USB driver, and all has been good ever since.
2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
Check Out My Latest Tune File: HERE
Originally Posted by Goldfinger911
thanks for the tip
Nick--
