can anyone elp learn how to log the logs??? please...
I need to know how to log VE tables and PE tables sorry about the confusion...
Hi,
Your question is still a little vague. What are you trying to archive etc?
Neither the VE nor PE tables are logged as such, but PIDs which enable you to determine if you need to make changes (i.e. Wideband input). These logged PIDs are then presented on a Map to show trends etc...
You may like to start by having a look at some of the interactive tutorials which cover some basic operation aspects of EFILive.
Also have a look at the 'AutoVE Tuning Tutorial' available in the 'Help->Tutorials' menu of the Scan and Tune tools.
Andrew
EFILive Crew
Couldn't have said it better myself.Originally Posted by Goldfinger911
DigitalEFI- EFILive US Distributor
sales@digitalefi.com
678/344-1590
finally got some logs but not sure what should I be watching as far as the PID's...
BlackBear, HSW N20 100 shot
Engine coolant temp
Throttle position
Rpm
Commanded AFR
Wideband AFR if you have a wideband
STFT's
Spark advance
Knock retard
are just some I normally log
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
