Results 1 to 5 of 5
Thread: trans relearn???
    Dec 2007
    Default trans relearn???
    i was just wondering if like the ppe, when you load a new tune, do you need to do a trans relearn? and if you do, how??
    Dec 2007
    General Concenus is yes, if you have a 6 spd the only way I know of is to reflash the stock TCM and there is a Tab that says TAPS and you just select reset TAPS.
    2006 Silverado LBZ Stock.
    Senior Member camcojb's Avatar
    Dec 2007
    Quote Originally Posted by petestoy
    the "reset taps" doesn't work yet.
    Jody
    Sep 2007
    is that in the process of being looked at yet? do you know jody?
    Dec 2007
    Quote Originally Posted by twister773
    yes, they are working on it according to EFI Live.
    Jody
    07.5 4X CC 2500HD, EFI Live, MBRP exhaust
    new updated website!
  1. ECM relearn procedure and VIN
    By killerbee in forum Duramax LLY
    Last Post: December 13th, 2009, 12:03 PM
  2. CKP Relearn
    By 91LS1S10 in forum Gen III V8 Specific
    Last Post: January 17th, 2009, 07:03 PM
  3. Crank Relearn
    By mk6racer in forum Gen III V8 Specific
    Last Post: May 15th, 2008, 11:05 AM
  4. CASE relearn for PCM with new LS2?
    By ArKay99 in forum Gen IV V8 Specific
    Last Post: January 28th, 2008, 06:08 PM
  5. CKP Relearn
    By 91LS1S10 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 29th, 2006, 08:21 AM
