Results 1 to 6 of 6
Thread: LB7 Stock Bin (Flash recovery)
    Nov 2007
    Default LB7 Stock Bin (Flash recovery)
    Anyone have a stock Bin for an 03 LB7?
    I have a corrupt Flash. I have the flash removed just don't have an actual
    bin to restore with.
    Anything that will boot an #12210729 ecm would be much appreciated.
    If you have one and are willing to share please post or Pm me.
    Thanks,
    John
    Well there are a few on www.holdencrazy.com under the stock tunes that should work, none for an 03 but there are 01s, 02, and 04s. Do you know the stock OS?
    Nov 2007
    Thanks for the reply and link. I looked at serveral, I'll go through the rest after this. They all seem to be in .tun format which is great once I get up and running. I don't have anyway to convert a .tun into a raw .bin
    I can use any OS for a #12210729, I need to manually burn the flash.
    (remove chip , burn, and resolder) Once I am booted I can use a .tun file.
    I'm just trying to fix a doorstop for a buddy.
    Thanks,
    John
    Ahh, I misunderstood you man, I thought it was just a chip that had been flashed improperly and needed a tune and OS to run it.
    Sep 2005
    Get a hold of Jesse AKA wait4me, he can proable give you the BIN file you are looking for.
    Nov 2007
    Resolved,
    Thanks for the efforts-
    John
  1. Raw Bin files for pcm recovery
    By mrrattle in forum General (Diesel)
    Last Post: November 22nd, 2020, 02:37 PM
  2. Stock truck idle problems after flash..?
    By samh_08 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2009, 09:07 AM
  3. Rough running after flash and return to stock, TPS problem?
    By Whodunnit in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: July 27th, 2009, 11:57 AM
  4. PCM "Recovery"
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2004, 03:52 AM
